It is currently Sun Jul 20, 2025 4:17 am
PostPosted: Mon Oct 08, 2007 3:59 am
Country / Location: Virgin Islands
Online Status: Online
Fret files
Posted: 06 October 2007 at 10:09am | IP Logged Quote canerider    Quote canerider
 First of all thanks alot for your replies and welcome. That was a great link and my problems pretty squarely fall under the uneven fret category.
I have low frets top E and B string around fret 3-7. Too much blues in A! Any previous fret work I have tackled has been with various grades of  wet and dry paper and a flat as you suggest. This worked well as it was nice and slow. But how to get rid of the flat fret tops after?
I am prettysure the truss rod adj is fine.
PostPosted: Mon Oct 08, 2007 6:11 am
with a Dressing file like this
PostPosted: Mon Oct 08, 2007 6:15 am
It will file the fret to round from the sides inward Stop when you have a very fine thin at the center of the fret .005" or less. Then you need just to polish them out. This is called dressing the fret.
PostPosted: Mon Oct 08, 2007 6:54 am
If access to a crowning/dressing file is a problem where you're located, a square or rectangular or triangle shaped file can be used after you smooth off the corners of the file to prevent damaging the fretboard. Here's a pic from frets.com. Notice the rounded areas on the edges, not just at the end.
Use it the same way Michael described above, only you have to file on each side of each fret.
Good luck!
PostPosted: Mon Oct 08, 2007 8:07 am
 Thankyou gentlemen.... and thanks for reminding me to listen again to that great Richard Thompson tune!
